Anything under half tank when I fill up will cause the car to stutter and stall on the first start up. I took it to Ford on to get the oil changed and have it looked at but the only thing they did was try to pull a code. "well there's no code so there's nothing we can do"
Psst.. not every problem has a code. I asked if the tech could go with me for 10 min to the gas station, but he only had one tech that was busy. Its a really small dealer here in Key West that does Dodge AND Toyota as well as Ford.
Anyway I left and filled it up and it stuttered and stalled, just as I thought it would. One of the guys there just said to not fill it up all the way.. while that MIGHT be a decent suggestion, that doesn't fix the problem that shouldn't happen to begin with, its a band aid. Suggested a EVAP problem.. well suggest that to the tech that looked at it so he can visually inspect it instead of the code BS.
I kind of made a video but Its pretty corny and probably doesn't show it as well as it should have.
and no I dont "Top off" the tank, and never have with this car. Once the pump shuts off, I remove it. Stopped doing that years ago.
Im moving from Key West in 2 weeks and by the time I get to my next location I'll be out of warranty.
