1 - 20 of 31 Posts
2016 ST1, FBO, GTX2867R Gen2 .64-AR, Spec stage 2 clutch, Quaife LSD, Fortune Auto 500 coil-overs.
Sooooooo... I have basically full bolt ons minus downpipe and I have mountune charge pipe+intercooler pipes... What "stage" cobb tune would be appropriate? I'm gonna go with stage 2, what you guys think? One other question.. I'm running a mountune tune 91 Octane but have since moved and have only 92 Octane available, is this a problem? I've heard you can run one less Octane but should never run +1 Octane. Thanks in advance ?
first, no down pipe means that you do not have a "stage 3" car, you need to run stage 2 tune or lower...
second, fuel octane... if you are running a 91 tune, then you are tuned to safely run on 91 octane fuel. you can also run higher than that, so yes 92 or 93 octane fuel is fine.
just don't ever run a lower octane fuel than you are tuned for! if a tuner tunes a car for 91 fuel, then putting lower octane fuel in the car will cause the engine to knock and then the car will pull out all of that performance that was added to attempt to keep the motor from being destroyed.
I think the best answer was No Cobb Stage Tune. Don't trust your car to a canned tune. Hook up with a tuner who will adjust and ensure you have that car running proper.
What's considered a "Stage 6"? At what point do we stop using the this specific term when it comes to modifying?
stage 6 is tri turbos (99psi), carbon fiber downpipe, neochrome windshield and 68" racing spoiler.
I'm working on that but can't find a tuner in my area. Mountune does revisions on their tunes which is kind of custom but not quite.
"stages" and necessary modifications.
If you bought your access port from mountune you also get a free custom tune. There’s a bunch of great tuners online that e tune thru data logs.
Actually that's hyperbole.
I have run E30/E40 tunes om 91 and I'm currently on 100 octane tune running it on 91. If I am on the way up to the track in Bakersfield (McFarland actually) I will put whatever octane I need in the tank and when I go up the Grapevine which is a 2-4% grade so that puts plenty of load on the engine, my timing is resorted.
I have run my best times at that track twice in a row with that method. Even when we pulled the plugs (OE heat range, came with the car) after I damaged the engine, except for #4 cylinder the rest were fine, I can post a pic if your curious.
I had a nitrous backfire that damaged the engine not doing the above.
Remember the car has a wide band in it already, it will not adjust boost like say my SRT-4 did based on air inlet temps at the filter. You get say 22 psi no matter the fuel or outside temps, what changes is how much ignition advance you get.
If your curious on 91 and nitrous I got zero advance. I had a can of VP 101 back at my friend's garage. I don't cry over spilled milk, bought another bullet now it has a GTX3071 attached to it.
Holla
And let me guess, you are running a standard Cobb canned tune with absolutely no refinements made will all that crap just like the OP is right?
Well forum you heard it here first, I don't want to perpetuate the hyperbole so DJfourmoney says you can safely run what ever octane fuel you want to with what ever tune you want to and your engine will be just fine! 0% risk...
Discussion Starter · #10 ·
Tell me more... Every part on my car is from mountune, I actually brought the car to them and they installed everything including the tune... I did notice when I connected my accessport to my computer yesterday that the mountune file was like 4x larger than all the ots cobb files. This is my first tuned car so it's safe to say I'm a newbie on the tune side of things lmao.
Discussion Starter · #11 ·
im not running a "canned cobb tune" I have them loaded on my accessport by default but I've never used them. My tune is apparently custom which I did not know as mountune didn't really tell me much, they had me load the tune and sent me on my way, gonna hit up Randy and find out more.
Hahaha yes!
Back when I had my Mustang the "stages" were starting to be applied to camshafts. That used to annoy me so bad.
At least with our application there's specific criteria but I don't refer to my car as stage "X". I guess I'm old school and rather blurt out my mods.
General consensus is that the Cobb OTS "canned tunes" are garbage and account for the majority of blown up STs we see here. They are too generic and cause some serious issues for some people. Definitely get a tuner to get you situated and don't worry about what "stage" you are. That "stage" bs started when Cobb released the Stage packages.
Cobb Stage Packages:
Stage 1- Intake and tune
Stage 2- Intake and FMIC and tune
Stage 3- Intake and FMIC and Downpipe and tune
Etc.
When you get ahold of a tuner (such as Randy) don't worry about "I have a stage X car" just tell him "I have this mod, this mod, and this mod" and he will get you situated. :)
Best of luck.
Sorry, in the original post you just asked which "Cobb tune" you should go with so I though you were just using the canned tunes that come in the device.
As many have mentioned above, just contact your tuner and let them know exactly what you have done to the car and they will get you squared away right!
Discussion Starter · #15 ·
Etc.
Best of luck.
every mod on my car is from and installed by Mountune.. The tune they gave me was based on my mods but unfortunately I waited to long for a revision so they told me I had to pay the initial tuning fee of $275 (approximately) again.. ugh stupid me lol you'd think they'd be a little lenient considering I spent over 3k with them but oh well, thinking of just starting over with Stratified. Thanks for the info and reply.
Discussion Starter · #16 ·
Yeah I havnt loaded any of the ots tunes yet but was considering trying one out for ****s and giggles. Think I'm just gonna get a custom tune from stratified.
I can certainly vouch for Stratified and they undoubtedly know more than most others regarding this platform. Great company to work with.
Discussion Starter · #18 ·
from what I've gathered they're one of the best if not the best. Thanks again.
The car adjust when you put 87 in the tank doesn't it?
Ratings drop 87 octane = 230 hp, 93 octane = 252 hp. There is no rating for 91 octane, but... My very rough estimation is 244 hp
I believe and it's been said before that the space between the top of the pistons and the first ring is very narrow. Another possible problem is the a tight gap for the rings to help with blowby and with initial emissions validation.
With that knowledge I fail to understand not so much an issue with the stock turbo but when doubling the output why running E85 should not be shortcutted by running blends. As I stated in another thread, it's been proven that the more gasoline you have mixed with ethanol the less effective it is. You get the majority of the oxygen content from as low as E20 but higher concentrations upto E85 and E98 have proven to provide extra in-cylinder cooling.
Matt Snow of Snow Performance has blogged that many full time E85 runners are also running his Snow Performance water-methanol systems.
On a stock turbo ST it's overkill, but you can run E30 and water-methanol together to get a couple of degrees of timing since that is the main power adders after bolt-ons with the stock turbo.
In-fact I know Bryan at JST mentioned when dyno'ing the Time Attack car when it still had the stock turbo that he could have made more but that was all he could squeeze out of E30 = 309hp.
Adding water-methanol would have certainly helped.
I know a few Mk7 Golf GTI/Golf R owners who are running APR's canned flash tune with a JB4 piggyback on top controlling water-methanol. This is a called a stacked setup and it's gaining in popularity.
My friend James runs this setup on his 11 second Golf R with the stock turbo. He runs E30 with 50/50 water-methanol. Both the APR flash tune and JB4 tune are 100 octane.
It sure is a custom tune. I believe you get unlimited tune revisions within 45 days of the first update. I got my AP from Mountune and Randy updated my car probably 10 times before it was perfect. Idk how you could get a more custom/refined tune than that. Maybe your thinking you need to put it on the rollers and tune it real time in order to be considered custom, but I don’t think anything more could be squeezed outa my car just because I put it on a dyno.
1 - 20 of 31 Posts
