121 - 140 of 387 Posts
2014 Focus ST3
Just listened to the video. Pardon the commentary, but I swear that thing sounds like the turbo on a tuned PowerStroke 6.7L (only a little higher pitched). I like it. (y)
Reactions: TurboGT
Discussion Starter · #122 ·
I took the airbox lid off for the video only. I can hear it through the closed box, but its more muted. I love the sounds this turbo makes, though, and agree the flutter sounds like a 6.7, especially A gen 1 with the double-wheeled turbo. Those things are talkative .
Discussion Starter · #124 ·
Discussion Starter · #126 ·
You try any 4th gear logs in vdyno?
No, i haven't. Probably should get out at some odd hours and try a few. I also haven't Run 93 since being tuned on e30. Which im more concerned About the 93 numbers than e30 numbers.
I'm curious to see if you get similar torque number as I did. I got a little over 400. I did run the heat on full blast to get the coolant temp below 190 before the log. I'm done tuning on both fuels. So now I'm just toying with it.
Discussion Starter · #128 ·
Alan went easy on the torque (ignition timing ramp) per my request on both tunes. I never want to run anything other than a stock clutch And that 400+ tq that panda got out of this turbo would be tearing up driveline components faster than a tuned k03.
My initial desires with this turbo was strictly more power on the right side of the dyno graph over stock. Because this turbo turned out to be a k03-esque torque monster, i wanted that tamed some.
Can you send me your final 93 and e30 logs so i can Compare?
Also care to share your vdynos with us here?
No problem. When I get home I'll send them over.
I'll post em up too.
Sorry for the delay. I got really sick yesterday after lunch. I'm still feeling under the weather today. Unfortunately working ridiculous hours since people are flying a lot.
Here is a the one I thought was 4th gear. I was wrong it was 3rd. The other, for comparison is a local FoST that is FBO and running e30. All my runs are on the same road, same lane, and pretty much same atmospheric conditions. Hot as balls Florida. The tire size difference is due to me running 245/40-18's instead of stock size. Fun fact. I was going through my datalog on this one trying to figure out the odd curve. I didn't go WOT until 4000 rpm. It was a gradual roll into the gas.
393917
This next one is the 4th gear run. I know is sloppy. I ended my runs early and he started his late. :confused:
393918
Discussion Starter · #132 ·
I'll Be damned. He managed to iron out that stupid boost dip?? Or was this just because you started the run late?
Reactions: TH_ST
Vendor
Just had @STallion18 on the dyno today. His car is factory catback with high flow downpipe.
I ended up using cobb controls to speed things up for boost control only. 93 octane, stock catback, rs airbox, wagner intercooler and powermax turbo. I recommend a bigger intercooler for these smaller turbos as the wagner is +20 after a pull so with our fmic and 3" catback I'd expect around 322whp on 93 gas and 345 whp on e30.
Great mid range torque, but I have to keep tq under 3500 rpm and less lower because of the fuel system.
I can hear @junits15 about to sell his 2867 now and buy another powermax after selling the one he just bought lolol
394006
394007
Discussion Starter · #134 ·
@MonsterTuned excellent Numbers. Do you care to share the boost curve?
Vendor
Yes, I feel like boost/timing curve on this turbo is a little bit of secret sauce since I had to spend the time figuring it out. I don't wanna giveaway the store :p
Discussion Starter · #136 ·
That's fair, i was just curious. It's definitely a finicky turbo in that regard.
2017 Kona Blue ST1
RS airbox :sick:🤮
I just ordered the PowerMax turbo today with a TurboSmart IWG75 internal wastegate. Can't wait to install it!
I have a TurboSmart Kompact BOV already installed on my ST... Does anyone know if I will need to get the focus RS spring?? PandaMotorsports website says this about the TurboMax....
  • "This turbo uses a Focus RS (2.3L) BOV. If you choose to upgrade the included OEM style recirculating valve, you must use a Focus RS BOV."
Does this mean I will need to install the stiffer focus RS spring in my Kompact BOV? I am a bit confused by this...
