As many of you know, i've advocated for the Garrett Powermax turbo since I found out about it from SEMA 2019. It caught my attention with Garrett reliability, Factory interchangeability, and (at the time) a promise of a 20% power gain. It sounded like everything I could ask for. Simple part replacement as well as factory reliability and what I assumed at the time would have been a power figure into the 300s on a conservative tune. Well, May 2021 came around and it was finally here so I picked one up as soon as I could.Now that i've completed a second round of tuning, I figure i'd post up about my experience for others to see.
First impressions: The turbo is still tiny like stock. However, the compressor housing is around 1/2” larger than stock so its a noticeable size improvement along with the advertised 52mm compressor wheel increase. It comes with a plastic bypass valve, which it's highly recommended you upgrade this unit (it uses a Focus RS unit). I installed a Ford Performancew one. When I had the BPV out I had a look at that nice GTX cnc machined compressor wheel. Looks solid!
Installation: You dont need a how-to. This turbo dropped in just like stock, zero fitment issues.
Driving: This turbo has factory characteristics. You won't be able to tell the difference other than an increased overall power level that parallels the stock k03. It does make some really cool noises though, and i'm using a factory closed airbox! I'm sure this thing would make some killer sounds through any of the hot-air intakes on the market.
Power: Prior to this turbo i have only run the factory tune, with stage 3 hard parts. So overall this was a large jump in power for my situation. Here's where Things get dicey, though. First off, there is a boost dip that occurs immediately after the wastegate opens. Whether you run the stock Garrett wastegate actuator, the Garrett wastegate actuator with more preload, or the Turbosmart Wastegate actuator with 7psi spring, the dip is still there. I think it has to do with the large difference in wheel size between the compressor and turbine, and how greatly the shaft speed reduces upon opening the gate. A large hot side and larger turbine wheel would have helped this unit in a multitude of ways. You can feel the power delivery momentarily drop when this dip happens.
Secondly- the overall output. This thing will absolutely maintain north of 20psi up to 6500rpm. While this sounds nice, the engine had ignition corrections above 8.5 degrees of timing. Due to this, the power had a sharp nosedive over 5500 and It did not feel great to drive, the power dropoff was worse than stock. During the second round of tuning I suggested that maybe the hotside is so restrictive that we can make more power using less boost and more timing. Alan agreed and started boost at 22, tapered it to 15psi by 6500, and ended up ramping up to 15 degrees of timing by 6500. Vdyno confirmed on several runs, this showed a solid 30hp 20tq gain from 5500 to 6500 and very noticeable seat-of-the-pants difference in acceleration. I'm much happier with this output now.
Here's a comparison of the Final tune with sustained high boost (red line), versus the final tune now, with tapering boost and more timing (blue line):
Heres a comparison of The two best vdynos. The higher torque vdyno (blue line) was on a 50 degree morning, the lower torque (yellow line) run was today, 65 degrees outside.
Here is Stock (green line) versus todays run (yellow line):
So with a Conservative 93 octane tune thats easy on the torque, Im around 285whp, 330 wtq on average. I'm sure with some more aggression in the tune it would be 300hp. I had planned to hold off and get this thing on the rollers before posting numbers, but that seems to keep getting pushed back and i didnt want to keep you guys waiting, so vdyno will have to do until that time comes.
e30 numbers are 321/358. Runs fantastic on the blend.
Some important notes:
All in all, whether i'd recommend this turbo or not depends on your personal situation. Horsepower per dollar it's on par with someone changing their car from stock to stage 3 ( 20whp for 1500 dollars total). Because of that I'm categorizing this as Stage 4, as it is NOT a big turbo nor makes big turbo numbers, but more or less is just another incremental step in power before jumping off the deep end into huge horsepower aux fuel and built motor territory. It drives just like stock in every way and will not change how the car responds with the exception of more horsepower. If you're looking to spice up your commute and not lose any of the stock turbo snap or stoplight-to-stoplight performance, this guy is for you. If you want to be a highway star and see how fast you can do 40-120 rolls, this is not your turbo. It fell slightly short of my expectations regarding power delivery. I was hoping to make 300 reliably on 93 octane, but unfortunately you would need to ride a fine line to get that with this turbo.
EDIT: finally made a video showcasing the sounds this turbo makes.
EDIT: Full throttle e30 Acceleration
- This turbo uses a focus RS bypass valve. Its highly recommended to switch the stock plastic unit out due to the boost levels being run. I used the Ford Racing bypass valve. I personally recommend a bypass valve over a blow off valve as it helps keep the turbo spooled better through gear changes by dumping the pressurized air back into the compressor inlet. Besides, if you want the noises, this turbo makes plenty of induction sounds and bypass noises.
- This turbo also uses a focus RS wastegate actuator. It is diffferent from the ST unit, and I had to machine the shaft of my ST unit and shorten it to accept a clevis to attatch on the Powermax
- With the above being said, I do NOT recommend changing the wastegate actuator since this turbo only responds well to a downward-sloping boost curve anyway. Its a waste of money.
