Hello
So Ive gotten the OEM strut out, and removed the top that holds the 3 bolts. Apparently for the ST-X coilovers, you need to use this piece and put it on. In the instruction video, I cant tell if he put the old bearing seal on it, but I think it should be on there. However, when I screw that piece onto the ST-X, there is barely any up-down play on the coilover. Is this normal? I feel like coilovers should have up/down play in order to absorb shock, but these dont. The top piece from the OEM shock completely stops any up/down motion when installed.
