1 - 17 of 17 Posts
Damn, not bad for what you get.
Hard miles indeed. But if you were planning on building an ST track car it's a nice deal with the cage.
I would love one of these as a track car. I had a blast in these cars in Tooele UT, but anyone buying one has to know that they have been beaten severely, over revved, gone off track multiple times, and suffered collision damage at one point of another. I'm certain that they've been maintained, because they wouldn't have survived otherwise, but I think I'd have to build one for myself using a street car. At the STOA event that I attended two of these cars were significantly crashed- and I can only imagine that each one has been through quite a bit.
Once again, I wish I had gone.
However, it's a nice spec list of what Ford thought the car needed for being beat on.
2014 Focus ST – Vehicle Specs
Power //
  • 2.0L Ti-VCT Turbocharged Ford EcoBoost I-4
  • 252 hp / 270 ft lbs torque
Cooling //
  • Enhanced cooling system for continuous track use
  • Custom radiator ducting
Brakes //
  • Carbotech XP20 front brake pads
  • Carbotech XP8 rear brake pads
  • 3” brake ducting for cooling
  • Stainless steel brake lines on all four corners
  • Castrol SRF brake fluid
Handbrake //
  • Era1 Handbrake assembly w/ custom mounting brackets
  • (installed handle removed)
  • Wilwood master cylinder w/ remote reservoir
  • Wilwood rear calipers and brake pads
  • Custom rear caliper stainless steel brake lines and mounting brackets
Exhaust //
  • Ford Performance cat-back exhaust system
  • Wheels & tires //
  • Michelin pilot super sport 235/40/r18
  • Arp wheel studs with open lug nuts
Interior //
  • Custom six-point roll cage
  • Recaro seats w/ford racing safecraft four-point harness
  • Rear seats / package tray removed
I know I am reviving an old post but does anyone know what the enhanced cooling they used was? Have a pic of the the radiator ducting? Did they use an oil cooler? Wish that would have been stated in the spec list. They took the time to list the XP# for the Carbotech pads, the tire type, and the lig nut type but just say enhanced cooling for the cooling specs.
· Super Moderator
2014 ST3. Garrett GTX2860R Gen 2.
@8FOCUSD might be able to help
Maybe he'll post some pics of everything with the front bumper off!!
Reactions: rob99rt
2018 ST1 Magnetic Gray
Discussion Starter · #16 ·
I talked with an instructor about that. Mountune radiator and intercooler. Whatever was available from Mountune at that time. 4000 feet altitude make it hard for cooling and boost.
Sorry Mods for the bump in it appears @Boogiesadda is still a member and had a question. Boogiesadda the radiator and oil cooler are CR components. It’s hard to get pics without disassembling the car, but it appears they were built to mount same as factory. All of the original plastics were removed and is ducted directly by a sheet metal box. These are the best pics I could get.
1 - 17 of 17 Posts
