1 - 12 of 12 Posts
I'd assume so. Forscan is a program anyone can download to their computer. You then need a Bluetooth obd2 reader to connect your car to the computer. It sounds harder than it is.
Sent from my SM-N910T using Tapatalk
Could i use his scanner to do that if i just download it and use the hard wire obd hookup? or could i use my cobb ap?
necro bump:
How-To: Using FORScan to change your Sync3 boot splash screen to "ST Ford Performance"
Use ForSCAN to locate this value: 7D0-02-01 xxxx xXxx xxxx
Change the value in the spot of the bold X to one of the following and save.
The default value should be 1.
B - ST Ford Performance
C - RS Ford Performance
D - GT Ford Performance
1 - Standard Ford logo
4 - Lincoln Presidential
5 - Raptor Ford
6 - Mustang
7 - GT350
9 - GT350
1 - 12 of 12 Posts
