1 - 2 of 2 Posts
COBB 591001 Focus ST 2013-2014 Polyurethane Exhaust Hanger Kit
Today we are installing COBB's Polyurethane Exhaust Hanger Kit on our 2014 Focus ST project car. If you have an aftermarket exhaust system on your Focus ST you may have noticed a slight squeak when driving or your exhaust pipes may have shifted slightly to the side, this exhaust hanger kit from COBB will solve both those problems.
These polyurethane hangers from COBB are far more rigid and sturdier compared to the weak, factory rubber hangers used on the 2013-2014 Focus ST. The new hangers help reduce excessive exhaust movement that can lead to the occasional rattling or rubbing that troubles so many drivers. These highly durable urethane exhaust hangers are exact replacements for the factory units.
This kit will prove worthy if your exhaust system occasionally knocks against the subframe or exhaust tunnel during aggressive driving. So whether you are taking a leisurely drive or really getting on it and pushing your Focus ST to the max, this polyurethane exhaust hanger kit from COBB will keep your exhaust securely in place and immobilized.
No tools are required to install these polyurethane exhaust hangers, although you may want to use a non-silicone lube to install the front hanger. If your putting an aftermarket exhaust system on your Focus ST we recommend picking up one of these exhaust hanger kits as well, and installing them at the same time will make things a lot easier.
For more Spool Tuning options of COBB products check out:
COBB Tuning | Spool Tuning
1 - 2 of 2 Posts
