I just chatted with Crutchfield to change the order to 2 pairs of Kicker 46CSC674 speakers all around. Doing the "morning after" review check ... a lot of people say the Rockfords are actually 5" with a big surround with bass criticism.
Stage 3 Motorsports also offers the same deal ... these CS speakers in 6.5", wiring and mounting rings for $155 ... or a step up to the KS package for $200.
13-18 Focus ST Complete Kicker CS Series Speaker Upgrade Package
13-18 Focus ST Complete Kicker KS Series Speaker Upgrade Package
They also include an installation video on their site:
Just spent my Saturday doing the four-speaker install of the Kickers, using the Stage 3 video as a guide (better than the Crutchfield instructions). I am pleased with the results ... doing A/B testing after putting one side in, you can definitely hear how MUDDY the stock speakers are.
Some install notes:
1. The Crutchfield adaptor rings have an inside set of mounting tabs, which for these 6.75" you snap off (easily and cleanly with pliers) and use the main solid ring for a flush fit.
2. Yes, cut out a notch for the wires to go through as in the video. I mounted them "upside-down" so the harness is on top.
3. I bought some double-sided tape to apply to the wiring harness plug to stick to the door so it won't rattle around ... more on that below.
4. The annoying bits, surprisingly, were getting the little cover under the door handles off (kinda tap around on it till it dislodges from its fit with nary a gap in the edges to pry loose) and wiggling the connectors plugs onto the speaker poles without breaking them (tight fit and sharp edges).
5. The rear doors were tricker than expected upon reassembly:
a. Making sure all the white plugs in the door card were in place (they can slide off easily) and lining up the little panel with the window control so it would snap in completely (keep your eyes on the bottom large "keel" tab to make sure it lines up with its slot so it can click all the way in).
b. I was able to disconnect the door release cable harness to take the door card completely off ... but be sure to test function plugging it back in ... the cable end twisted off its plastic rails so had to straighten that out.
c. When double-stick taping the wiring harness to the rear door, I originally did it to the rim of the speaker adapter (red NO circle in pic) but then the front of the door card wouldn't quite snap in ... there's a little plastic protrusion at 12 o'clock about the speaker grille that you have to clear (red circle in pic) ... so I reoriented the harness forward and flat for clearance (green circle in pic with check mark).
Now just needs a road trip for a good test!
