Nyet, plugs are mine. I need 6 for the edge, and 4 for the focus. Lol
Are they in production still? npa or pboys is my only hope, they were closed, aa, az only had ltr6
Have you tried to find any lately? Some places have one or two, most want 12.00 to 15.00 each plus shipping. Rock auto is the best price and they are out of stock.Why not try the 95605?
Right on. If you can't find them let me know, I can ship them usps priority on Monday which should be 3 days anywhere in he country.i have a napa near me, im going tomorrow, they were closed tonight. Very old school, my type of store, you have to walk pass their machine shop, to get to the parts shop!
Great sticky! Question that wasn’t answered: what if I’m using the motorcraft plugs? My engine definitely isn’t new so I don’t want to trust my torque wrench. It says for torque instillation 7.2-14.4 lb-ft I guess I could go on the heavier side? Nothing about anti seize on the box eitherHere's what the makers of your plugs have to say...
Keep in mind that torque specs are drastically affected by the condition of the threads and seating area. Gunked up threads will cause you to hit a torque value before the plug is fully seated. Just a heads up.
I suggest and prefer the non torque wrench approach. In which the plug is installed by hand till it touches the seating surface, then and additional percentage of a turn or turns is added. This procedure is laid out below by both manufacturers as an alternative to torque specs.
Torque specs are only good for CLEAN threads. Odds are that your threads are not perfectly clean, unless you have a fresh motor. So keep this in mind when you choose how to tighten your plugs.
Spark Plug Installation | DENSO Auto Parts
Spark Plug Installation | NGK Spark Plugs
Always use the Manufacturer's installation procedures. Who knows their product better than the people that did all the R+D to make it.
Did somebody say anti-seize?
DENSO SPARK PLUGS
Denso Says no. They are worried about over-torquing.
5 Things You Should Know About Spark Plugs | NGK Spark Plugs
NGK say no as well. They have a antiseize plating on their plugs already.
These will work fine, no issues. Just make sure gap is .026 - .028 and be careful not to damage the electrodes.I searched but did not find a clear answer:
I have an AP3 but I have not installed it. I also have new Ruthenium spark plugs (95605). Can I install the spark plugs with the expectation of tuning the car in the future, or will those plugs not work well with the stock tune?
As I mentioned previously- I have four Ruthenium plugs (NGK 95605's), new in the box (never installed). I had a few minutes and checked their respective gaps over the weekend, and they were all at .028". Should I close the gap on the plugs to .026" expecting the gap to widen over time once in use? If I leave them at .028", should I expect that to change (widen out of spec for the tune I want to run) and have to pull the plugs to change or regap them?These will work fine, no issues. Just make sure gap is .026 - .028 and be careful not to damage the electrodes.
Also, I found mine on CarID if you out in your car info it won't find them. under $9.00 each. Use any ecoboost 2.7 like Fusion sport or Edge.
I'd tighten them up to .026" .As I mentioned previously- I have four Ruthenium plugs (NGK 95605's), new in the box (never installed). I had a few minutes and checked their respective gaps over the weekend, and they were all at .028". Should I close the gap on the plugs to .026" expecting the gap to widen over time once in use? If I leave them at .028", should I expect that to change (widen out of spec for the tune I want to run) and have to pull the plugs to change or regap them?
Thanks in advance for the advice!!
I am aware of the pitfalls of damaging the electrode on this type of plug- what's the best way to adjust the gap? I have a gapping tool (the circular type) as well as a set of feeler gauges.I'd tighten them up to .026" .
Lightly tap them on something hard, and keep measuring. Or just put them in at .028" to save yourself from getting into trouble.I am aware of the pitfalls of damaging the electrode on this type of plug- what's the best way to adjust the gap? I have a gapping tool (the circular type) as well as a set of feeler gauges.
