ANY HELP PLEASE?
Issues when adding a kicker key amp
I have a 2015 MK3.5 ST3 Ford Focus which has a sound Symposer that uses the speakers instead of other ST models /years that use a pipe from the engine to increase engine noise inside the car.
The issue is that i have paid someone to install a kicker Key Amp (small little amp) to boost the SYNC2 volume which it has done successfully but it has also increased the sound of the Symposer and any audible beeps (ie reversing sensors), attached is a image of where the amp has used the speakers leads (the passenger side of the centre console), the installer said this was the place to get the speakers signals from but surely it should be from the back of the SYNC2 module?
any ideas?, and has anyone else installed an amp to boost the car speakers and come across this problem - surely there is a way of increasing the SYNC2 volume using an amp and not increasing the Sound Symposer and other audible sounds from inside the car at the same time.
You can see from the image where he has cut the original speaker leads
