1 - 3 of 3 Posts
I bought a 2013 st about 6 months ago and I'm slowly learning what mods the guy did before me...he has a Breedt sound symposer delete on with two ports.one is blocked off the other isn't, should it be ? I may add BOV ,will I run a hose to one , what about the other?
Most people hook the blow off valve to the sound symposer delete so it doesn't blow off as often as it does in stock form. Especially when you install an aftermarket bov. The other ports are used for a myriad of things Boost gauge, boost reference for meth injection, anything you need to reference the boost pressure for. I would cap it better than putting a screw in it if you're not going to use the port to take it out and put a pipe plug.
1 - 3 of 3 Posts
