Question is why buy the kit to cover that bolts a plate to the port opening vs just disabling the symposer by disconnecting the power harness to it? What are the benefits to the kit?
If you buy a port cover with a vacuum fitting you can run a few systems off of it like BOV and Guardian angel.Question is why buy the kit to cover that bolts a plate to the port opening vs just disabling the symposer by disconnecting the power harness to it? What are the benefits to the kit?
Also, to clean up the engine bay or to mount an oil catch can at the "stage 1" location.Question is why buy the kit to cover that bolts a plate to the port opening vs just disabling the symposer by disconnecting the power harness to it? What are the benefits to the kit?
Nope. Part of the sound symposer delete is to unplug it. Just make sure you use a zip tie to keep out of the way.Will it throw/store a code if I just unplug it?
It will have a code but no check engine light. If your worried you can leave the valve assembly hooked up and delete the rest of it.Will it throw/store a code if I just unplug it?
Just unplug it when the engine is idling. It will stay closed and I think it sounds so much better without it. I have had mine unplugged for months and no CEL.Yeah like why bother with the plate if you can just throw a switch and shut it off?
One point that has not been covered, is the fact that the Symposer Diaphragm has failed on people, leading to an intake manifold/boost leak. Yep, it's a point of failure, hard to tell how common it is because pretty much everyone ditches it, lol.Question is why buy the kit to cover that bolts a plate to the port opening vs just disabling the symposer by disconnecting the power harness to it? What are the benefits to the kit?
Nope, removal is necessary. Its not super common, but a symposer delete is cheap, cleans up the engine bay (easier to wrench on), and can give you a vacuum source.So unplugging it when it is closed will not prevent a leak?
My god, so worth it!its worth the delete alone just to clean up the engine bay a little bit...
