1 - 13 of 13 Posts
hey, new here
My ST just came to the dealership on Tuesday, I am picking it up Saturday.
They let my take it home on Tuesday as my test drive to inspect it/ wash it,
Drove it about 100kms and couple times I had a hard time getting into 5th gear, some kind of resistance other times it was butter smooth
Anyone experience that before?
hey, new here
Every now and then I have noticed that it can be a little wonky getting into fifth and accidentally will shift into 3rd. But it has only happened a handful of times (Only owned mine for a month).
Yeah the main gears to watch out for are 3rd and 4th, your fine
Replaces the chintzy rubber bushings on the trans. and the base of the shifter to eliminate most of that slop. Cheap and relatively easy install. Here's a link:ALUMINUM SHIFTER BUSHINGS
Congrats. I have no issues with shifting at over 50k miles on my 2013, but I have aluminum shifter bushings which definitely give a more solid feel. Like Keebs said, it's a cheap fix so why not?
I have not had any problems with my 2016. (Changing gears) May I ask why the Mustang had to go?
I just traded my Camaro for my ST on Thursday, and while it gets better MPG, the tank is so much smaller than I go through gas so much faster and have to refuel more often. It's going to take some getting used to. At least each fuel up will be cheaper with smaller tank.
1 - 13 of 13 Posts
