41 - 54 of 54 Posts
Discussion Starter #41
Uh oh. Rear crossmember rotted out. Made it up to RDC headquarters the next day to grab one off an MK3. YES THEY ARE INTERCHANGEABLE! came home and wire wheeled it then brushed some POR15 on it and the LCA's. Hoping to install tomorrow. Waiting on the new springs to show up.
Sent from my SM-G925V using Tapatalk
Awesome stuff you're putting together there mate! Keep it coming!
any differences between the two sub frames? Same mounting for the sway bars and everything? I see they kept the reinforces tabs for the endlinks on the LCR's that started with the SVT's.
Discussion Starter #44
Nope. Identical. Bolts in.
The LCA's are off of the MK1.
That escalated quickly.
Discussion Starter #48
Yeah...i wanted to delete the ABS, move the computer, tuck some more wires, redo the intake. Turns out the clutch was shot also, it's at clutchmasters being turned down. This thread isn't as active as other forums so I don't update as I should...
Clutch should be shipped back tomorrow to reinstall and get the motor back in the bay for mockups.
I painted my mounts and reservoir tuxedo black, turned out fantastic
Discussion Starter #49
Pretty well up to date now. Tapatalk is awful for uploading pictures now.
Discussion Starter #52
Can you elaborate on that manifold setup for us? Not sure i have seen anyone tap it before :)
Well sure.
The controlling end of it is Snow Performance Stage 2 kit and the hard lines are Pro Meth. Drilled and tapped, glued with E6000, which is meth resistant btw.
Should finish everything up later today. Mount tank, wire up low fluid sensor, pump, solenoid, and manifold solenoid.
Very cool, i am assuming since you are running four ports, you will be tuning for a power increase vs just the protection/cleaning some run it for? I really want to see this car in a roll race :) I know what my car does but picturing the same power with like 500+lbs less weight and a more streamlined body than my hatch 🤤
Keep up the good work (y)
41 - 54 of 54 Posts
