3
I am putting a 2.3 Ecoboost into an elise, build thread in other builds if you are bored, basically 2.3 crank, 2.3 manley rods, 2.0 Pro pistons from Speedperformance, Piper rally cams (11mm lift inlet 272 degrees) and lightly ported head. GTX2867R turbo in external tial 44mm wastegate.
But had some issues on the dyno, see below
First thing, is the vacuum pump. As i dont have a servo leaving it open to atmosphere builds pressure in the crank case, Blank it off and / or remove the drive gear and no pressure in the crank case. Any ideas why this would be ?
I had an 11psi spring in my tial wastegate, that on my previous engine hit 11psi on the nail. Fitted to the ecoboost it hit 2 bar and they had so much det they backed it off with no added boost from the controller. Took one spring out, should be 4psi and it hit 20psi.
Lastly at 20psi the engine was detting like a bugger so they had to retard the ignition, they did this until the EGTS started going through the roof. Could this be compression ? The engine is a 2.3 crank, 2.3 rods, with Pro pistons from speed performance that should give 9.3:1. I thought the engines used the same pistons and had similar comp ratios ? any idea if my combo would increase the
