Status
Not open for further replies.
1 - 17 of 17 Posts
THE BASIC FACTS
A. Item for sale/trade (model, specs, etc.):
  • Mountune Intake Manifold (Used)
  • Mountune Fuel Rail (New)
  • Mountune Oil Baffle (Used)
  • BBK 62MM Throttle Body (Used)
  • Radium PCV Catch can with Drain (Used)
  • J9 Engine Cover (Never installed; did not fit see details below)
B. Condition: See above plus details below
C. Price: $1000 Shipped; Payment via Paypal; shipping to US lower 48. Selling as full package.
D. Location of item: Indianapolis, IN
This is the intake setup from my recently traded in Focus ST. Used parts have less than 5000 miles on them. Intake manifold has some scuffing around bolt locations (was torqued to Mountune instruction torque spec using a torque wrench so I assume this is normal). Fuel rail is brand new (planned on going big turbo with aux fuel but never did). Oil baffle, throttle body, and PCV catch can are used. All are clean except for oil which is to be expected given what they are. J9 Engine cover did not fit my air intake (early Mountune with stock pipe going into the turbo). I talked with the guys at J9 and opted to not send it back since it was imported from the UK. It should fit most aftermarket air intakes.
Selling this as a full package. If it does not sell within the next month or so, I may consider dividing things up.
391233
391235
391234
391236
391237
391238
391239
Discussion Starter · #2 ·
391240
391242
391243
391244
391245
I have a feeling I will eventually have to split it. That said, I am really hoping someone wants to do the full setup at one time like I did. It is not difficult to remove/swap out separately, but it was definitely easier to do it once than several times. Hopefully I priced it well enough to get a taker on the full set. Asking less than half of what I have in it.
Reactions: Duece McCracken
dang... first local FS I've seen and nothing I need. That's my luck!
I have 3 other listings up now... maybe one of those will work out for you :)
2016 Focus ST3
No picture for the J9 cover?
2016 Focus ST3
So is this also part of the package?
Discussion Starter · #11 ·
Yeah it is. At least until I unbundle if I do not get a buyer for the full setup.
Reactions: W4R
Discussion Starter · #14 ·
Discussion Starter · #15 ·
Sold!
Moved to "Sold Sold Sold".
1 - 17 of 17 Posts
Status
