1 - 5 of 5 Posts
So what happens when you don't have any AS BUILT files...AND you decided to **** around with FoCCCus and Forscan??
I tried to remove the shift indicator and do the global open/close.
Now my car is just sorta ****ed.
  • Windows pause every few inches,
  • Front window controls are reversed,
  • Headlamp Fault Service Required notice
  • And about 6 malfunction lights on ABS Air bag, check engine, traction control, (!) light, light
    [*]Not to mention the endless DTC codes when scanning...
I just want to get the car back to stock working order and I'm worried.
Does anyone know how I get my car back to AS BUILT for all systems???
Go there, you should always read your car and download and save the file before messing with variables. Just for this situation.
You can get it from ford on the web. Go to Forscan site and search it you’ll find a link easy enough.
Reactions: itsjustdibella
I had found that but it wasn't working. I did find this though. https://www.motorcraftservice.com/AsBuilt/
I downloaded that, wrote it to the BCM and IPC and basically back to normal. I didn't check for any DTC after I wrote it though. I know the gauges didn't have as many lights on...just the ones that went off due to me retrofitting a '15 steering wheel on my '13.
So my ‘15 wheel is now on the ‘13 FoST NOW the wheel is on and I have cruise control EXCEPT the volume buttons on the ‘15 wheel are increasing volume and changing the source, and the speaker button changes source as well.
I have the slippery traction icon and the center info button lit up.
And a crap load of DTC codes in Forscan. Will these ever just go away?! I mean damn!
1 - 5 of 5 Posts
