1 - 20 of 65 Posts
So after a decent amount of boost. About 10 lbs and up i am burning oil. Its blue smoke. I have the speed by design red kit. Running a 91 full custom tune. And i also have the steeda intake oil catch along with a jbr manifold oil catch. I emptied both out at about 1300 miles. The steeda catch was way more full then it has ever been. So i emptied both catches and they were both a very muddy brown thin liquid. So this was 3 days ago. Today i noticed im still smokin alot, i popped the hood and the steeda catch is full again. Greyish muddy brown liquid. Very concerned and want to fix what ever it is as soon as possible.
going to state the obvious, that the oil isn't overfilled?
Aftermarket PCV?
Compress test on cylinders?
Detonation correction going crazy from excess oil in cylinder if any is making it through?
If the Steeda (between the valve cover and the cold air intake tube pre-turbo) is filling up fast then you have a lot of blowby.
So unless the PCV valve is leaking under boost or is otherwise stuck open, it's time for a compression test and perhaps a leakdown test.
You may also want to check that none of your catch can hoses are kinked or restricting flow, but really the compression and leakdown tests will tell you if you have a motor issue or not.
Hope that helps,
Mark
Hope that helps,
Mark
Thank you. Its looking like i. Gonna start with a compression test. After that i may be kinda lost in the sauce.
Well of course we all hope for the best, but if it's the start of ringland failure and you catch it early, your block, head and crank will be usable. You'll just need a budget for rods and pistons (and bearings and rings), a little machine shop work, and some incidentals like a head gasket, new PCV plate, etc. (and maybe a rental if she's your daily).
IOW, don't blow your budget on 50-year-old scotch or vintage port getting "lost in the sauce"! :)
Keep us posted?
All the best,
Mark
Keep us posted?
All the best,
Mark
What would be a rough estimate if i catch it early?
Discussion Starter · #13 ·
As far as the deck surfaces go. Get a long hand sander and some 600 grit paper and clean both surfaces. As long as you didn't have head gasket problems you will be good without machining the block and head
And will can all this be done witbout pulling the engine. Or does it have to be dropped to do all this.
Discussion Starter · #18 ·
It can but I would pull it. Timing will be the hardest with it in the car. It's easy to get out if you remove the front crash bar.
Oh man at that point i dont have the tools for that. I would probally have to take it to a shop. Warrenty wouldnt cover it no way. Maybe insurance. But i doubt it
1 - 20 of 65 Posts
