1 - 6 of 6 Posts
2014 Ford Focus ST
So I have a tiny little oil leak presumably on the left side of my engine at the top. The leak seems to be right beside a belt and pulley. This is a 2014 ST with only 50k kms on it.
381352
It seems a little dark around that area and I'm wondering if this is an easy fix or if this is a tough one. Is it doable myself or should I call my mechanic? Any help would be appreciated!
A: look at your belt. Looks chewed up. Looks like a lot of belt dust in the area as well.
B: check your engine mount. I had a leak that looked awful. All over the side of the engine and it was the engine mount. Clean it off and inspect.
2014 Ford Focus ST
Yeah I do notice my belt is blackened on one side. What usually causes that? Are there any common sources of that?
I think my engine mount is fine. It doesn't appear to be leaking or have any residual oily stuff on it.
A guy I know who is a mechanic suggested it might be an axle boot. The oily stuff is the consistency of thick grease with suspended dust and dirt in it almost. @UnfocusedST @turboguy327
So you’ll have to look at your axle boots.
Just look around your belt, see if a pulley is off or anything looks weird. Unfortunately you can’t just pull the belt off and spin the pulleys. Belt isn’t supposed to be reused.
1 - 6 of 6 Posts
