I am wondering if anyone who owns an ST2 like myself is wondering if heated seats can be added. Any info or thoughts?
The one you where looking in too.I haven't looked into it all yet since I am not ready to do it. But which male plug. There is more than one.
Well there is a connector under both seats at the front of them. The element connectors would snap into those connectors. Then the other side would be the body harness connectors. Then you have the switches that turn the heat on and the body hardness has connectors from it to plug into the switches.The one you where looking in too.
5 settings plus off or 0. I'm guessing each independent seat module is seeing the switch position and setting the right current to the pads based on that input. So to wire the factory pads and switch you will also probably have to get the modules too. Most of the aftermarket kits only have off,low, and high.What controls the temps? I know the switches have like 3 settings or is it 5?
I never got that far into it as the price started climbing high. I can say that when I did my ambient lighting I looked for the wiring for the switch in the body harness going to the console harness and those wires were missing if I remember correctly. I was going to tie into them for the ambient but it wasn't there.What is the part number for the factory heating pads. I just read through this thread again but didn't see it (I might be blind). Also, do we have a part number for the heated seat module yet, assuming it doesn't come with the pads.
The way I want to do it, yes. As long as the pigtail harnesses are available. My concern is the variable heat and how that is handled. It isn't something I looked into yet. Is there something that regulates the voltage? I think the factory switches have 4 positions. Off and then 3 levels of heat.So half the harness would have to be wired up using the schematics.
Yeh from what it looks like the switches have a signal power running through them to tell the module how much current to send to the pads. It doesn't look like the stock switches will be able to be used without the module.The way I want to do it, yes. As long as the pigtail harnesses are available. My concern is the variable heat and how that is handled. It isn't something I looked into yet. Is there something that regulates the voltage? I think the factory switches have 4 positions. Off and then 3 levels of heat.
Where is the module located? I assume there are 2?Yeh from what it looks like the switches have a signal power running through them to tell the module how much current to send to the pads. It doesn't look like the stock switches will be able to be used without the module.
one on each seatWhere is the module located? I assume there are 2?
That's what it's looking like. Might need a roll of wire and those schematics, and a few pigtails or connector pins.I got ahold of an ST3 console with all the E-brake and switches. Now I just have to figure out how to get everything else I need. From what I can see I will need the heater pads, and control modules to put this onto an ST2?
