1 - 20 of 20 Posts
I have been configuring my own files with the parameters I want but most of them stay at the same value or move every so often. I have tried selecting different ones but still the same issue, some work but others don't. I also have no DMRs available only PIDs and OBDs. I have tried only logging via laptop without creating the configuration but still won't change the values. I have tried other configuration files people have sent me but only some parameters work correctly. I am currently using version 15 of livelink and my strategy is GMDG15V, it is a 2016 Focus ST. If anybody could help me I'd be so grateful I've been going crazy lately trying to get it to work and spent countless hours in the garage hooked up to the car via the laptop.
How can I do that, because I thought I have been doing that?
"I have tried only logging via laptop without creating the configuration"
This is what I was referring to. Take laptop to the car, plug it in and turn on ignition. There is a new update for Ford strategies. Click I want to create datalog config. file button and validate all pids. Build it from there.
Oh ok I see what you mean now, I tried that as well and it gives me many more choices but some still stay at the same value or change very abruptly. Ex: ambient 72F couple minutes later 76F and stay there and skips between different values instead of steadily changing. There is also still no cylinder corrections 1-4. could it be something to do with my strategy being to new?
Yes it can. They now use the spark advance and spark advance v2. You can see the correction in those parameters. Try the new update and see if it has the DMR's now. We had the same issue with a new 16 mustang. @Blivit was a great help
What new update are you referring to? I thought that version 15 for livelink was the newest one? I really appreciate your help and input by the way.
Well that sucks. You'll be plenty happy once they get it prepped and ready. A lot of people dog on the SCT for apparently no reason in my mind. Map switching on the fly and traction control don't bring any value to me.
I can't log some DMRs either. Mainly ignition dmrs; SCT is supposed to be working on it, no update yet.
I wish I had knock counts that I could log. Not the end of the world but it would be nice. Got something in the works that will hopefully help out.
I just added more ethanol... There was only a 3.49% correction at E30 so there's more room to add ethanol.
When it doubt add octane...
1 - 20 of 20 Posts
