So i installed my big turbo, im somewhere in the 26lbs range right now, but my sct will only read 22.47lbs. Does anyone know how to fix it, i created my own datalog and i cant figure out which parameter would read it correctly. Thank you!
Add "tip prs boost kpa" pid. Take the # and subtract 100 for atmosphere.So i installed my big turbo, im somewhere in the 26lbs range right now, but my sct will only read 22.47lbs. Does anyone know how to fix it, i created my own datalog and i cant figure out which parameter would read it correctly. Thank you!
Kpa is showing around 26lbs. I just wanted it in psi lol the psi is ran off of pid, so it may not allow itAdd "tip prs boost kpa" pid. Take the # and subtract 100 for atmosphere.So i installed my big turbo, im somewhere in the 26lbs range right now, but my sct will only read 22.47lbs. Does anyone know how to fix it, i created my own datalog and i cant figure out which parameter would read it correctly. Thank you!
It doesn't usually however there are some ECU's that have a pid that will. Depends on your strategy. I always just used the KPAThank you, the normal pid wont read it correctly. I tried a few different ones but couldnt find it.
