1 - 8 of 8 Posts
Can someone explain to me how Sct ignition correction numbers work? I see how cobb does it and I understand it. However when I data log mine with my x4 I get numbers between 0 and 40. What does a knock look like?
I really don't want to bother my tuner. Just want some more information.
Ugh, I hate SCT logs. They dont really spell anything out easily. Makes you wonder what data the tuners are using.
I'm in the same boat. I thought I had a grasp on it, but it appears I may be wrong. Gotta do more research.
Glad I went AP3 for the focus, i use SCT for my other fords without AP3 support.
Discussion Starter #3
I've searched everywhere and can't get a definitive answer. It's definitely frustrating.
What is the name of the item(s) you are logging? Are you using the included items on the X4 or did you add a configuration file from livelink?
Discussion Starter #5
I have a config file from my tuner. The ones I'm talking about are ign correction cyl 1,2,3, and 4.
Those will not display numbers from 0-40 if the file was set up properly. The ignition correction parameters are direct memory reads from the pcm. That means that they are strategy specific. If the configuration file is for a different strategy, the file will not be correct. What is the strategy of your car and what is the strategy in the configuration file?
Discussion Starter #7
When I get a minute to look at the files I'll let you know. I use my kids pc. He's currently playing minecraft 😂. I would assume it has to be for my strategy. Everything else reads correctly. I'll get a screen shot of it.
TC button not engaging i have some datalogs in here if you want to take a look i use sct livewirets i assume its the same thing
1 - 8 of 8 Posts
