1 - 5 of 5 Posts
My winter wheels have developed slight rust staining that I can't seem to get off. Scrubbing with a blue sponge has taken some of the light rust off, but I can't get it all off. I currently use diluted Simple Green to clean my wheels. Has anyone else had this issue, and if so, what have you done to remedy it? See pictures below and the link below to my winter wheels. Thank you.
https://www.tirerack.com/wheels/WheelCloseUpServlet?target=wheelCloseUp&wheelMake=MSW&wheelModel=Type+14&wheelFinish=Silver+Painted
Alloy wheel Tire Wheel Rim Automotive tire
Alloy wheel Wheel Tire Auto part Rim
It is just brake dust. It has some iron in it, and the iron rusts. You need a iron removing wheel cleaner. If you don't have that you could try a real wheel cleaner. Nothing is going to be a spray on rinse off though. You will need a wheel brush, probably something small to get in that corner.
Dub would be good. Don't let it dry, but let it dwell long enough to turn colors. Agitate with a brush and rinse off.
I would not use simple green on anything but that's me. It's very corrosive on unprotected metal.
1 - 5 of 5 Posts
