1 - 20 of 20 Posts
running stratfied tune and car has rough idle and misfire on 2-3 about 20% been running tune for 6 months. 25k mi. any advice or diag. changed plugs and coils. going to try a reflash and see if it runs differently and deal with MIL
mods: green filter, mountune intake elbow, mbrp intake, rev9 catless DP, roush 3in cat back, 1 step colder plugs gapped to stratfied specs, msd coils. jbr short throw
Put your stock coils back in and try again.
Reactions: ddotffoeg
and check spark plug gap. Could also be a clogged/faulty injector... I'd also sand the neg battery ground as well as the grounds underneath the airbox.
Reactions: Cowlynz
MSD coils are crap now. No longer made with the same quality and performance generating like back in the day. Change back to factory coils and problem solved. Friend of mine had MSD spark plugs on his FiST. Completely robbed power and made it run like ****.
Always were junk if you ask me. I bet I've seen 100 dead MSD 6 boxes with my own eyes.i know several drag racers that carry several in stock on race days.
I hope it's fixed.
I have been having the same issue too, I am running ngk spark plugs (one step colder) and stock coils. I installed the plugs and tune at the same time and I have been having this issue since then. Cold or warm the rpms goes up and down slightly but if I drive forward and back right issue goes away then I let it warm up a bit. I flashed back to stock and the issue is still there. I checked the plug gap many times nothing is out of spec. The only solution I haven't tried was swapping back to stock plugs.
What tuner are you using and have you asked them specifically about it? What gap are you running?
What is your misfire count? What CEL are you getting (if any)? This car will misfire while cold every single time, but are you receiving misfires while just cruising or specifically under WOT? Have you checked carbon buildup on intake valve?
It's not their fault; my friend has similar mods and tune and he doesn't have this issue. I also removed the tune and it's still the same.
Also here is a picture of the plugs
I didn't say it was, but there isn't anyone better to ask than your tuner in a time like this. Just to double check the tune. It's obviously either the plugs, the coils (maybe not seated properly), or the tune. If that's the only things that changed. Just covering the bases, Stratified knows what they're doing.
I was clarifying for others it's not really a tune issue, Stratified are great they sent me a revised tune and it did reduce the idle roughness but not completely. They raised the idle rpm (which I used to do anyway whenever I wanted to tone down the roughness and the vibrations when I turned on the heater). Monday I will get stock plugs and flash back to stock (I am tuned for colder plugs) and see if that eliminates the problem.
No misfires just rough idle.
Mine idled pretty rough too. Stage 3 with colder plugs and 55k. I traded it in for a brand new 2017 and it felt the same.. lol
1 - 20 of 20 Posts
