1 - 10 of 10 Posts
As some may have seen my threads regarding my AWE Touring catback, it's too loud for my tastes. With that being said, I'm contemplating what to do with it. I contacted AWE, and they could sell me the mid pipe w/their resonator, but it's quite pricey to me. So I'm wondering if I should look into a different resonator, and have it welded to my current pipe? Does anyone have any recommendations for a resonator (that would go before the muffler)?
Did you install a sound synposer delete kit that will help,if you don't want to get a tune.
Im still trying to figure out what this has to do at all with his question????
OP- I wish I had a good answer for you. Im not sure what resonator CNT uses on their catback but I think it would get the sound where you want it. I love my CNT exhaust.
Most people that put on exhaust systems will remove the sound symposer system because when they're combined, it's usually a bit too much.
Yeah I installed a high flow resonator from magnaflow and did a muffler delete and it resulted it a huge amount of drone with the stock sound symposer. Deleted that and it's so much better now.
I'm thinking about adding a resonator to my exhaust system too since it's a bit raspy as it gets into the higher RPM range. I've been reading a lot of good things about the Vibrant Ultra Quiet Resonator (1141) and might pull the trigger on that.
I have a resonator that I cut out of my mountune exhaust if youd like to buy it from me you could probably have a shop weld it on....its 2.5" in/out tho...idk if youre running a 3" exhaust or what.
Do you happen to know the dimensions of the resonator shell on the Mountune exhaust?
1 - 10 of 10 Posts
