Not with ST1s, I believe.umm, those are stock LED from Ford, why replace them?
I just turned off the warning in the IPC via Forscan. The BCM still sets an error code, but no lights or warning.So I need a resistor to run led brake lights on a 2015 st
No, only for the turn signals. I did all LED’s in my 15’ ST2 with no resistors. Ran into a small grounding issue with the wiring but that had nothing to do w/ the conversion.So I need a resistor to run led brake lights on a 2015 st
