1 - 6 of 6 Posts
Once I start having wrap put on my car I'll ideally want the main Ford badges to go on top of the stripe, hence not having any TS borders around them. I've been told that on some models you can't remove the main Ford badges. Is this the same with the Focus?
Floss is your friend. They're stickied on
Sent from my ONEPLUS 6 using Tapatalk
Fishing line... works as well as floss but doesn’t break as easily.
Discussion Starter #4
Really, they're glued on? At least they're not bolted on. What sort of glue do they use? Is it tough stuff?
Discussion Starter #6
I'm going to have it done by the people who're doing the wrap work, so it shouldn't be any problem then. My main worry was that they're bolted on, which would mean I'd have no chance.
1 - 6 of 6 Posts
