Removing ST3 headlights
1 reading
2.9K views 3 replies 3 participants last post by  rambleon84
#1 ·
I am having a really hard time getting the low beam bulb out of the housing. I disconnected the headlight but cannot get it out. Any suggestions would be greatly appreciated.
#3 ·
What do you mean you disconnected "it"? The harness from the entire assembly or just the plug to the HID bulb? I just swapped out my bulbs yesterday for some 8000Ks after swapping them for some 7000ks last week so I'm getting pretty good at it
#4 ·
If you are having issues, just remove the entire headlight. There are only two bolts attaching it to the car and both are easy to access.
When you say low beam, i am assuming you are meaning the d3s/d8s bi-xenon HID bulb. Those are attached with this style C clip that is a pain to reach, see here for what i am referencing:
http://www.focusst.org/forum/focus-st-appearance/128849-hid-bulb-clip-removal.html
You need to turn those like a quarter turn iirc then bulb should come out
