So when I was installing my intake a while back I had a moment of stupidity and accidentally used the engine cover mount peg in the wrong location. (see photo) When I realized my mistake I tried to remove it and the plastic broke (probably because I also over-tightened it :doh
So now I'm stuck with the engine cover mount broken, and in the wrong location. Now it's time to change my spark plugs and I have to remove the intake pipe to get to one of the coil packs.
I'm thinking I might just have to break off the rest of the plastic to get down to the metal, and use a bolt extractor tool but I'm worried I'll **** it up worse if I mess with it more. I tried using pliers, and vice grips but just more of the plastic chipped off. Any suggestions? Is there a normal bolt head under the plastic perhaps? Thanks in advance for any help!
