1 - 8 of 8 Posts
Has anyone done anything to change or remove the awful rubber pieces that the bottom of the license plate pops into? I hate them and want them gone.
I'll admit. They are pretty horrendous and my plate/plate cover doesn't sit flush because it pops "off" of the rubber things then sits above them. You could just remove them and replace them with 2 more bolts I imagine.
Always could just take them out. I just wonder if the holes they are in are threaded.
Reactions: Toneloc427
I pulled the rubber plugs, put in nylons to the the square holes and use 4 screws to mount my plates. They never rattle.
mine was missing one from the time I purchased the car
still havent replaced it,
I removed the rubber plugs, and inserted two new plastic screw receivers so now my plate is held on by 4 screws instead of two which is how every damn car should come so that the plate is not flop d!cking around and rattling...
you can buy a pair of screws and universal plastic screw nuts at any car parts place for like $2.
it worked so good, I did the same thing to my wife's Escape the next day*!
*full disclosure: the next day, I actually then removed my top screw insert nuts and used those in the wife's Escape, and then used the new ones for the top of my car so that way I had 4 all new AND matching nylon screw insert nuts(not pictured).
1 - 8 of 8 Posts
