10-4 good buddy!Good deal, keep us posted
No, because it is closed-circuit and sealed away from the elements. It only handles the filtered air entering and being pressurized by the turbo.Should the Mountune BPV be cleaned every 6 months? I'm guessing the same maintenance procedures should be applied however they do not mention anything with their product. It was a pain in the azz to get that thing installed.
For the sake of testing, I'd really like you to install the stock BPV, clear the code, and run it for a week or so that way. If the code never returns, id say, yes, go ahead and get the turbosmart. I'd rather be 100% sure this is the issue before you spend any money.Alrighty so more updates… really pissed off now.
It’s doing it again, so I rebuilt again except this time I took extra care to thoroughly clean everything and this time I used gun oil to lube up all the o-rings and it’s still doing it. So now honestly I’m just thinking about getting a turbo smart 50/50 since it’s recessed inside the turbo housing and thus not as exposed as the Boomba. TurboGT, thoughts on this? Is there a better recessed not so exposed BOV I can get that you recommend? I really don’t want to install the exhale kit btw lol, too much money and effort.
Hey so I have some upsetting news...For the sake of testing, I'd really like you to install the stock BPV, clear the code, and run it for a week or so that way. If the code never returns, id say, yes, go ahead and get the turbosmart. I'd rather be 100% sure this is the issue before you spend any money.
No, don't buy any parts still. Also leave the stock BPV in place. We need some constants here.
In post number 5 you said the WGA was good. What PSI did the gate begin to crack open at when you tested?
Also, do you have a means to datalog the issue i talked about in post #11? Theres an ST owner locally who also had the same noise concern you talked about in post #5, where the exhaust makes a very weird reverberation sound under the exact same circumstances you described. I rode in the car myself and verified this personally. I offered to datalog the car with him at a later date but he seems uninterested in looking into the issue farther. He later said he talked to his tuner who advised him this is typical of a failing wastegate on the stock turbos, but i cannot confirm this personally because he hasn't fixed the car yet.
I believe the wastegate Is on its last leg. Just to make sure and to ruled out anything else, the engine is not overheating and the coolant level is Ok? Had you tried pumping air into the wastegate actuator to see if it’s holding it.?
If you can attach a bicycle tube air valve to a piece of vaccum hose and plug it to the WGA. Use a hand or bicycle pump. Around 6 PSI it should start moving out ,fully extended around 12 PSI. Don't use an air compressor. It should hold the 12 psi. Since the WGA holds the wastegate tightly, is you can disconnect the WGA rod it will give you a better idea of the condition of the bushing.
Alrighty gotcha. I actually have a hand vacuum pump so I’ll use that.Exactly what he said. Just adding that I own and use a Mityvac hand pump for jobs like this.
So what do you mean by “under pressure, not vacuum”? And yeah very true, I should’ve considered the brake pedal.Make sure you are testing the wastegate under pressure with the hand pump, not vacuum! A failed vacuum pump wouldnt effect wastegate control. But it would effect BPV operation and the brake pedal would be rock hard
Typically with these hand pumps you can select "vacuum" or "pressure" via a switch on the side. Meaning when you pump your hand you supply either vacuum or pressure out of the hose. You need to supply pressure to the wastegate. It does not operate from vacuumSo what do you mean by “under pressure, not vacuum”? And yeah very true, I should’ve considered the brake pedal.
Ahhh alrighty, then I’m going to have to buy a new one since mine just does vacuum to my knowledge.Typically with these hand pumps you can select "vacuum" or "pressure" via a switch on the side. Meaning when you pump your hand you supply either vacuum or pressure out of the hose. You need to supply pressure to the wastegate. It does not operate from vacuum
Ford does not sell just the waste gate acuator, as far as I know you would have to buy the whole turbo to get one.More updates, got to the actuator a bit better today, found the rod has a touch of play, I’m assuming that’s bad and I need a new actuator. If so, where should I look for a stock one? Unless you guys think I should just get a turbo smart WGA…
Alright so I’m going to have to go with the Turbosmart. I’m assuming what I found leads to be a bad WGA? I would assume you don’t want any play at all in the rod.Ford does not sell just the waste gate acuator, as far as I know you would have to buy the whole turbo to get one.
