I recently used the FoCCCus 8.6 Beta for my modified Spyder Projector Headlights with H3 HIDs, using a Kensun Cancellor/Capacitor pack. Although it turned out I didn't need the cancel modules, FoCCCus was able to get rid of the Low Beam error code.
1. Head to #14 and select Alternate HID
2. Head to #17 and select without dipped dim headlights. *NOTE*This is a MUST in order for the Alternate HIDs to have an effect. Please remember, if after this change, you then disconnect and reconnect the headlights from the main harness plug in the engine bay, you'll have to re-read the BCM file and flash the ECM again. I found this out the hard way.
3. If you want the Global power windows go to #184 and select global power windows & sunroof. Wonderful stuff.
Next I'll try #196 and try the LED turn signal lights.. after I try the Valet modes.
I think the only thing that you might be missing out is software outside of FoCCCus for the ELM327. I keep about 3 different software applications for this on my laptop.
