201 - 211 of 211 Posts
I have a 20" light bar. I shaved my grill and bolted it to the crash bar. It's bright. Makes people mad. And gets you pulled over.
I just ordered a pair of Hella 500's and was wondering if you guys could help me figure out where to wire the power to if I want the power to be completely seperate from the Fogs, Hi Beams, etc? Any help is appreciated.
I have a LED light bar as well installed and hooked up with my high beams. It's super subtle and you can't even tell it's there during the day. 16731138_10158327504575694_191932673_n.jpg 16832195_10154975583951303_5957495067788413065_n.jpg
I have a 20in inside also. Pulled power from the fuse box and wired a switch into the console
Sent from my VS995 using Tapatalk
What fuse did you get the power from?? Because your switch in the center console is completely separate than your fogs,hi beams, etc. correct?
Sorry forgot to update. Ill get a picture today for you.
Yes its completely separate. Power to turn the relay on and off is from the sunroof fuse with a jumper and power for the light bar is under the hood. Will update in a few hours
