New to the Ford Focus scene and was thinking about lowering the car, not too much, using springs only. Since the car has Mc Pherson struts up front, I assume that lowering will decrease my front camber (less negative) due to the lowering, correct? I also the rear will gain more negative camber due to the double wishbone setup. If you drop the car on H&R springs can anyone advise what the drop might be and the result camber?
Is there anyway to adjust in more negative front camber, should i need it?
