1 - 13 of 13 Posts
Yes, I've done a search and don't see a definitive answer. Also, many of the replies that contained pics, have had those pics removed. I was going to use the day off to remove the MBRP catback, and install my Mountune system. I'd like to use jackstands on the rear section, as I do not believe I'll need to lift the front. Where to jack from? If possible, I'd like to lift the whole rear at once. I was hoping no not use the pinch welds unless it's deemed the best location. Any assistance would be appreciated.
i usually jack the entire rear end up off the subframe in between the two lower control arm mounts. as far as jack stands, I put mine under the rear lower control arms because i couldnt find any other place to put them. probably not the best idea, but it worked for me as i was very careful and made sure it was solid before i went under the car. good luck. also, i would highly suggest putting the front on jack stands too, otherwise the downpipe to catback connection will be a pain to get to.
I used a jack under the LCA, directly under the spring and it lifted both sides fairly quickly.
Ive heard and seen pictures of jack stand points in the mid section of the rear suspension.
Subframe, put Jack stands under pinch welds
For my Mountune CB install, I used Rhino ramps up front n jackstands under pinch welds in rear. Worked great.
Do your jack stands have grooves built in for pinch welds? Or did you have to put anything on the stand to cushion/support the pinch weld? I'm worried that if I rest the weight on the jack stand cradle it'll bend the pinch weld.
You could always put a cloth over the top of the stands. I've never used stands with detent for pinch welds.
Before I bought steedas jack rails (buy them) this was my favorite little chart.
Line art Illustration Art Compact car Parallel
Reactions: JOEFNB
I always use a small square of old carpet. Works well.
Reactions: ST_Fan
1 - 13 of 13 Posts
