1 - 7 of 7 Posts
Just picked up a set of stock premium ST wheels with pzero all seasons for the dedicated winter setup. What pressure should be run in these for cold weather winter type driving? I have em inflated to 37psi.
Discussion Starter · #2 ·
I may do a 40f/38r setup
Winter I tend to inflate a couple of PSI higher..we get so many cold swings. If I set psi to 38psi when its 40f, it can easily drop to 0 the same week, dropping psi to 34. Every 10 degree drop can lower the psi by 1. So if you see big temp swings, you may want to keep that in your mind.
+1 to this
We hit zero here in STL and I had 27psi all the way around. :(
1 - 7 of 7 Posts
