1 - 16 of 16 Posts
I have a 2014 Focus ST. It recently started requiring me to press the push start 10+ times to get it to start. Any ideas what could cause this?
Your button's switch is malfunctioning or a short somewhere both sound like reasonable explanations. Do you abuse the button by hitting it hard or anything? I haven't ever heard of this happening, but it can easily happen just like any other button.
OR, are you meaning that the car is cranking but not starting and the button is working fine? In that case the starter or battery could easily be of issue
When I push the button I can hear a click, but the engine does not turn over. If I continually push the button it eventually starts.
Sounds like a bad battery. Is it the original?
Keyfob battery low? Car battery low?
It could be ignition switch on the clutch pedal.
Good luck
Could also be the starter or the starter solenoid (often the solenoid is part of the starter) failing.
You can tell if it's the clutch switch, because if the car doest see the clutch being pressed, it will tell you need to press it in the cluster.
I don't think it is the switch because every time I press it the lights dim and there is a click. Seems to me like it might be starter or battery like some have said. It is just weird that it will eventually start after pressing several times.
If lights dim then yeah, check the battery and terminals (maybe they are corroded).
Have your battery tested before you just throw another one in.
Autozone does this for free, OP. I'd take it there and have them test it for you real quick then you'll know if you need another or not.
Discussion Starter · #12 ·
Had battery tested and it was good. Got a new starter that I am going to put in tomorrow.
I have to do the same thing with my lawn mower to get it started, but only have to push the prime button about 3-5 times... :D
1 - 16 of 16 Posts
