1 - 9 of 9 Posts
Anybody running the pumaspeed heavyduty 3port boost control solenoid?
Figure if i have to replace it might as well upgrade.
Think the factory one i have is causing my boost and throttle closure issue.
Looks to be like a well made unit. I would call and see it the stock unit has the same plug or is there a way to make it work. Why do you have to replace the stock unit?
I'm thinking either my factory boost control solenoid has a issue,or my boost tap location on the turbo coupler is not good.
Everything boost and throttle wise was ok earlier this year according to my logs,but i replaced the turbo coupler in may along with adding my breedt im and cp-e catless dp.Now i have a boost issue that in turn is closing my tb blades.Here is a brief datalog i did yesterday.
datazap.me | redfocusst | 2863r turbo boost solenoid issue
Well upon trying to figure out a boost issue i found the cap on my t fitting was coming apart.
Propeller Soil Auto part Vehicle Propeller
Thinking that may have been an issue.
Yea i would say so.After taking the t fitting out and just running the hose direct from my boost solenoid to the boost tap did a 3rd gear datalog,boost was looking normal 25-26.4lbs till i had a boost spike of 28.77lbs @ 4,700 rpms which triggered my ga.Also had some abnormal throttle closure from 4,700-5,600 rpms.Waiting to hear back from my tuner.
Turns out my factory boost solenoid is fine.Looks like the cheap rubber vacuum cap coming apart was the issue.
That should not happen again as i have installed some mcmaster-carr high temp silicone vacuum caps,one on my t-fitting to boost controller and 2 on the oem bpv solenoid that is not used anymore.
Food Cabanossi Cuisine
1 - 9 of 9 Posts
