1 - 17 of 17 Posts
I had 4K miles when I did mine. I'm at 8k miles not and only had the car for 13 months lol it all really depends on who your tuner will be.
Your shop will probably do it on the dyno so $500 is actually pretty decent. If you bought your turbo from a vendor that tunes as well odds are they supply e-tunes with the turbo kit. E.g. Stratified, freektune, Panda, etc.
Ah ok. Yes it's a full dyno tune
Yer can't really compare the two (with respect to $). The e-tunes work by sending datalogs taken on the street (or track) to a tuner who analyses them and revises your tune(s) until they are happy that the tune is running well. This can take anywhere from several weeks to several months of forward and back.
The dyno tunes usually take 5-8 hours on the dyno and they adjust the tables in your car for everything from low speeds and rpms to WOT runs to redline.
The e-tunes are great and these optimisations have been done by the tuner on a different car and they (the tuners) are more focussed on your WOT runs. If stratified lived near me I would have gotten a dyno tune, but they don't so I am doing an e-tune with them. Great vendor who know their stuff for this platform.
Well after a whopping 2 months of having my 2017 ST, I just ordered up a Garret GTX2867R and AEM v2 meth kit. I've done the supporting mods, intercooler, full 3" exhaust etc. Anything else I should know? I'm having my shop do it as they are certified Cobb pro tuners.
You won't be disappointed. Swapped mine at 29k, sitting at 56k now, and love my car! I would recommend a rear motor mount, to enhance traction and eliminate wheel hop. You may want to consider a Guardian Angel (stratified product) or something similar to prevent uncontrolled overboost, especially if you're going to run WMI. Something happens to a vacuum line and 1 pull could blow that stock motor. my .02
http://www.stratifiedauto.com/index.php?main_page=product_info&cPath=116_94&products_id=217
Enjoy man!!
Discussion Starter · #12 ·
lol Good point
Serious question though, kit is in, everything is buttoned up tight.
The car is only producing 23-23.5 PSI of boost under full throttle. I spoke with Strat they said the turbo is optimized between 23-24 PSI. Is this a normal boost level for the GTX2867R? Just want to make sure before we start optimizing the tune for that boost level.
lol Good point
If you're on pump gas yes. Only way to up the boost is wmi, aux fuel, e30, 40, 50 etc.
Keep us posted. I'm in the same boat, bought mine on Tuesday (09/26) already have the AP, waiting on Stratified to send me my tune. Over the next month I'm going to get all the other typical mods to support a big turbo then pull the trigger on it. You running the stock fuel system?
lol Good point
Did you do the install? If so about how long did it take and is it a one man job?
Discussion Starter · #16 ·
Well after a bunch of head scratching the car is 98% there. It's putting 370HP to the tire and my shop Evo thinks there is a bit more to be tuned. Very happy with the build.
I did not do the install myself, I'm more than comfortable doing 90% of the work myself but past expierenxw has taught me certain things should be started and finished by people who do it for a living.
I'm running the stock system on water meth
Anyone with an ST in Vancouver area should definitely check out Evolution Performance, their sh!t is wired tight.
I agree with what you said, if you know 90-95% of the job...it's still something that could ruin your car if done wrong so let the pros do it. Then if it is done wrong you can go after them about it instead of being stuck lol
1 - 17 of 17 Posts
