Yeahhh
Starting to record canbus data
Inviato dal mio LE2123 utilizzando Tapatalk
Could you help me with this? I have this Amazon.com: BXLIYER Android 10 Double Din Car Stereo Fit for Ford Focus 2012-2017 Head Unit - 9.7 Inch 2G+32G - Free Rear Camera Canbus - Support Sat Nav Bluetooth WiFi Steering Wheel Carplay Android Auto DAB 4G: GPS & Navigationgive me the link of your head unit.
on. mine one I had to modify the wire to force the learn of each button from UI. you have to cut pink cable from 54 pin connector and link it to key 1![]()
Inviato dal mio ONEPLUS A6003 utilizzando Tapatalk
it's similar to my last one... ask meCould you help me with this? I have this Amazon.com: BXLIYER Android 10 Double Din Car Stereo Fit for Ford Focus 2012-2017 Head Unit - 9.7 Inch 2G+32G - Free Rear Camera Canbus - Support Sat Nav Bluetooth WiFi Steering Wheel Carplay Android Auto DAB 4G: GPS & Navigation
I can't get my swc to work
Here are some pictures of my connectors and canbus. Do you have a wiring diagram for mk3.5 or know what what wire is for the swc? The radio has a key 1 and key 2 wire that can be hooked up to if needed.it's similar to my last one... ask me
There is 3 connectors total. It's all plug and play and works great other than the swc. I've went into the swc and tried to manually program each button like the instructions say but the radio isn't recognizing the buttons when pressed. Car is a 2016 with the 4.2 inch screen from the factory.Do you have sync 1 or 2? The installation is simple, there would be 3 connectors plug and play with the 2 of APM and one of 54pin if sync2
4.2 is sync1, usually the 1 had swc working without any mods...There is 3 connectors total. It's all plug and play and works great other than the swc. I've went into the swc and tried to manually program each button like the instructions say but the radio isn't recognizing the buttons when pressed. Car is a 2016 with the 4.2 inch screen from the factory.
Do you know what wires in the stock harness are the swc wires?4.2 is sync1, usually the 1 had swc working without any mods...
Strange
I don't have a connector that big with that many pins? Check my pics of my connectorsplease cut this wire, connec tthis wire to key1 wire.
then steering wheel key can set working![]()
Because you have sync1... I don't know the wiresI don't have a connector that big with that many pins? Check my pics of my connectors
Hello, did you manage to fix the problem with swc?I don't have a connector that big with that many pins? Check my pics of my connectors
yesss!another Italian!!!! yeah!
Strange, with sync 1 usually works
