Hello everyone,
I may have a problem with my Focus' transmission and wanted to get your input before contacting my local ford dealer. I'll try to explain the best I can...Explaining transmission problems can be difficult if you cannot witness it yourself.
When downshifting from 6th to 5th gear, I feel and hear a grinding, metal, tinny sound. I can only feel it through my left foot (clutch pedal). I will be cruising in 6th gear, fully depress the clutch pedal, and about 25% of the time I feel and hear something grinding if I give the engine a little throttle. I do not rev very high...I feel it even if I rev to as little as 2500 rpm. I hear and feel this when leaving the gear lever in 6, when I'm moving the gear level to 5, and when the gear lever is already in 5. I do not feel or hear this when downshifting to any other gear. 5th to 4th is fine for example. I even feel it when I deliberately shift slowly (Depress clutch pedal, wait a moment, rev as little as possible).
My only engine modification is a Damond Oil Catch Can. I doubt this would have any effect to the transmission or what I'm feeling and hearing. Does this problem sound familiar to anyone? Do you have any clues as to where this sound and feeling would be coming from?
