1 - 11 of 11 Posts
Today I installed a LSD a LWF and a new clutch i get the car all back together and now it wont go into gear. It will however shift when the car is off so I'm not sure what the problem is. The car was shifting fine before the install.
I want to add that my pedal feels not normal I was expecting some change but this feels different.
Correct, If you did not mark key locations when taking it apart you can cause severe damage to the trans and engine if it catches just right. you can shift with the car off because the engine is not spinning...its kinda the same reason you can up and down shift by revv matching. You will def have to read everything that came with the LSD, and take it all apart and visually inspect that everything is installed correctly..most likely it was the clutch assy you installed wrong and not the LSD.
Can you put the clutch plate in backwards on these cars? I've done that before on my s10 with a t5. It acted the same way.
Lol I didn't read the clutch plate side that said "FRONT towards engine". So I put the side that the springs stick out mashed up against the flywheel. So no matter if i pressed the clutch in or not, it was spinning the trans gears. We jacked up the back end and watched as I put it in gear, even with the clutch pedal pressed, and the wheels were spinning lol.
Luckily it only takes ~30 mins to drop the trans out of an old truck like that. The focus on the other hand... good luck.
Discussion Starter · #11 ·
Well I figured it out!!!! with help from Clutch Masters and CFM we came to the conclusion it was the release bearing. Not sure why or how but I could never get it bled down properly. So I pulled the trans again and swapped in the old release bearing to check and sure enough the car is working again.
1 - 11 of 11 Posts
