1 - 8 of 8 Posts
Vendor
Hey guys, if you are building your motor and you want to get a little more out of it, or if you want to get a lot more out of it. Be sure and check out these Piper Cams. We'll be running the Ultimate Road Camshafts in our shop car.
Piper Cams Mild Road Camshafts - $819
The BP255 cam is a straight forward installation with no modifications or additional parts required in order to use this profile. This is the first level of cam tuning used where high torque is required for towing / touring. (In/Exh duration = 244/234 | In/Exh Lift = 8.64mm/8.00mm)
Piper Cams Fast Road Camshafts - $819
The BP270 cam is a straight forward installation with none to light modification and parts needed depending on vehicle. Generally referred to as the stage 2 of cam tuning this profile performs well when used in conjunction with other stage 2 tuning products such as free flow exhaust systems and remaps, giving a good torque and power increase in road cars. (In/Exh duration = 256/244 | In/Exh Lift = 9.60mm/8.35mm)
Piper Cams Ultimate Road Camshafts - $819
The BP285 cam is by nature designed for modified road / track day cars and as such may require additional parts and or light machining of the cylinder head and piston crowns. Generally referred to as the stage 3 of cam tuning, this profile retains the tractability required for road use whilst giving good mid range torque and top end power, this profile works extremely well with ported and polished cylinder heads and throttle bodies. (In/Exh duration = 264/256 | In/Exh Lift = 10.85mm/9.70mm)
It is recommended to upgrade your valve springs when doing the fast road, or the ultimate road cams.
Piper Cams Valve Spring Kit SINGLE SPRING - $269
Depending on price i would be interested in a stage 1 or 2 set.
Reactions: EdgeAutosport.com
So thats 2? We would probably need at least 5 people to get a better price. I will see what kind of price we can do and then create a GB thread.
I will share with the Southern MD club. Might be a few more who are interested there.
1 - 8 of 8 Posts
