1 - 8 of 8 Posts
Hey folks,
Something weird happened last week. After hard driving on the highway for 15-20 minutes I noticed a lot of power loss in 3rd and 4th gear. It felt like clutch slip or a clogged cat. The car would rev but the car didnt move accordingly. I immediately took it easy after that. Ever since then it has been driving okay. No slip in high gears, performance still seems to be a little off but I could be imagining it now.
Any thoughts on what it could be? Easiest way to test for a clogged cat? No codes.
If rpms increased but car did not move, that would indicate a clutch issue.
If rpms did not move and speed did not increase, there would be a performance issue (not necessarily a clogged cat).
Reactions: ST1Dale
rpm definitely moved but I can’t recall how much it moved. The issue is the car hasn’t done it since?
If you have another hard run, see if it does it again with similar driving conditions.
I have done hard pulls and it seems okay now. Although I haven’t done anything after 20 mins of hard driving. Could the clutch be more inclined to slip when hot?
2018 Ford Focus ST1
What are your mods? Are you running the stock intercooler or an aftermarket? Any idea what your charge air temps were when it cut power?
I am 91 tuned with 5” INTERCOOLER and cold plugs. Unfortunately I didn’t have the charge temps on the gauge. That was another thought I had! But my charge temps have never gone higher than 10 above.
2018 Ford Focus ST1
Probably not heat soaked, then... Could be the clutch, though. See if it does it again in the future. Good luck.
Reactions: TurboGT
1 - 8 of 8 Posts
