1 - 20 of 22 Posts
Hi all
Bit of a weird one 2015 mk3 st
Took it for a blast and all of a sudden it seemed a bit flat power wise
Got the codes read and then was some about timing and other stuff cleared to then see what comes back
Only faults about lost connector to bcm, passenger door, aipm and the instruments
looked at the battery today and both terminals are corroded - as you can half see in the photos the APIM is going into saver mode when being scanned but not sure if thats normal when being read
its a DV6T-10655-AB which i think is 590CCA which not sure if this is correct for the car
However when I was testing it I was in 4th put my foot down doing 60mph and it didn't even move
My mechanic has said drive it until it throws an error and bring it back....
When I start the car it sounds fine and idles fine
Do you think this could be electrical gremlins? I'm thinking this as the car seems to run fine and alongside the connection faults with other components that are working fine Or do you think it could be something else
Thank you for your time
Font Material property Gas Tree Technology
Communication Device Gadget Finger Gesture Portable communications device
Communication Device Gadget Gesture Finger Font
Output device Communication Device Gadget Font Finger
Output device Gadget Communication Device Computer Font
Gadget Communication Device Cloud Font Sky
· Super Moderator
2017 Kona Blue ST1
Sounds like a loss of electrical to me.
Reactions: MtnMan and Slidsnke
That's what I'm thinking as mechanically it starts and turns over smooth as you like but has the issues with electrics
Thank you
· Super Moderator
(Snip)
However when I was testing it I was in 4th put my foot down doing 40 and it didn't even move
Please don't go wide open throttle in 4th at that low of a speed. That's deep into LSPI territory and you can damage the pistons doing that. 3rd gear at 40, that's on the edge of safe .. But 4th? That's asking to crack ringlands.
· Super Moderator
Reactions: Slidsnke
· Super Moderator
2017 Kona Blue ST1
60 is fine in 4th, but your original post said 40 so I was a bit concerned...
40 kmph = 24 mph
60 kmph = 37 mph
@Slidsnke keep it above 3k revs mate and outa boost in higher gears.
Fecking car, so this is what its currently complaining about however the timing fault has not reappeared and the car seems to drive ok
engine sound control monitor status 5 loss of monitor line input
misfire rpm 861 engine running time 1:44
evaporative emmisson canister purge fault
crankcase pressure sensor curcuit is currently unreliable
equivvalence ratio lambada bank 1 sensor 1
engine coolant temprature sensor out of read codes range p1116
exhaust temprature out of range p1127
Brake switch out of codes range p1703
Clutch Switch Out Of Read Codes Range p170A
Lost communication with body control module
lost communitcation with door control module
control module communication bus off
HVAC
intake camshaft position timing over retarded (bank1)
IPC fault
PDM fault
PCM DTC 1
I didn't see you report any attempted fixes yet. Start with getting the battery terminals cleaned and BMS replaced. Tell your "mechanic" to just do it then run your scans. Why he'd tell you to wait for codes is ridiculous when you have obvious corrosion at the battery. These cars are very sensitive to voltage problems.
If you're still having problems replace the megafuses in the High Voltage Junction Box next to the battery and clean up ALL of your grounds.
Reactions: Slidsnke
Discussion Starter · #11 ·
When we plugged it in the first time we didn't check the battery tbf, the car seems to be driving fine ATM though which is really weird, it did absolutely piss it down the day before i had the codes come up
I personally think its electrical because the issue would still be there if it was mechanical but my mechanic disagrees and hes been doing this 30+ years i trust his judgment more than my own :L
he seems to think the electrical is a seperate issue and that was why he wanted it driven until it errors because at the moment the only codes are
HVAC
IPC fault
PDM fault
the cam pos fault hasnt come back and the car hasnt bogged down since
Discussion Starter · #15 ·
Failure to fully understand and appreciate how bus communication in modern cars works, 5v control, the sensitivity of the electronics, etc.
I get that, his boy did say he hates electrical work and he's not done any of it for me before but everything he has done previously on my money pit mondeo ST and the misses mondeo has been very good and very well priced and has done it in emergency when I have needed it as before covid I had to drive to the office for work
And the other bit is it hasn't cost me anything for him to take a look neither I haven't spoken to him since the initial code reads though as he's incredibly busy ATM with other responsibilities
I have brought some dielectric grease and stuff to clean the terminals and a multimeter to check the fuses etc though
As I have looked at the error codes and one of the reoccuring causes is electrics/wiring for pretty much everything that is displayed so gonna give it a once over there's lots of stuff on here that will help thank god
Discussion Starter · #16 ·
I'll go through that should be able to do that myself tbf thank you bud
· Super Moderator
2017 Kona Blue ST1
The two 50 amp Midi bolt on fuses that power the BCM (body control module) have been a known culprit for electrical issues.
The post I referenced earlier will show which I'm referring to.
  • Helpful
Discussion Starter · #19 ·
so update on the situation, cleaned up the battery cables and the terminals, the negative monitor was not very corroded tbf the front was, the cables themselves didnt look like acid had seeped or the battery bay
the fuses in the junction box tested fine, however now the terminals have been cleaned up and the white cable relocated the APIM error code has gone
My reader is unable to check the BCM (not a feature of my reader) though so will need to have that read.
PCM is only showing P1703:00 AND P170A:00 Brake and clutch switch out of self-test range
The other point of concern for me is the evap purge canister purge fault
This is what im seeing the following in the live data whilst going for a drive after the battery maintence, from a 10 min monitoring of a spirited drive still accelerates badly but very intermittent
Commanded Evap Purge(%) this is constantly changing
Evap Emmission Canister Purge Fault "Yes Error"
Evap Emmision Cannister Vent Valve "OFF"
Evap Emmision Cannister Vent Valve "0%"
should the commanded and actual be matching? if so if this is off then this is dead by the looks of it
i have had a look to see if i can replace myself and it looks easy enough the existing one has green clips and there is yellow markings on some bolts and parts on the car including the evap purge assembly is this normal as i thought the OEM part has white clips or is that irrelevant
and how much could this part affect performance, could it cause hesitation and misfire?
or is there anything else i should be looking for in the PCM stream
Thank you
· Super Moderator
Thank you
The purge valve is basically a maintenance item. I changed mine at 50,000 miles and I have a spare that I keep on hand because I know I will need it. Clip colors are irrevevant, as you stated. Yes it can cause misfire and hesitation when it's not working properly, and yours looks as if it is not.
1 - 20 of 22 Posts
