1 - 4 of 4 Posts
Im new here:
I drive a 2014 Ford Focus ST. A slight clicking noise started a day ago. The engine light also came on. The Code is p0012 (camshaft position timing bank 1). I feel this is due to low oil levels due to a leak that I did not know about. (Note: The oil light never came on.) Has anyone else had this problem? Do you know what to do? Please help. John Charles Stamm
How low is the oil? The clicking noise is the springs in the actuator retracting (Does it on fresh build motors with no oil in them when turned over by hand) It could be a number of things. Low oil, bad phaser, bad phaser solenoid, position sensor, timing chain or tensioner. I would change the oil and clear the code and see what happens first
Hello Slstomper
I added 2.5 -to-3 quarts to get it up to normal. I honestly don't drive that hard. Other people have told me to change the oil also.... I'm worried about damaged camshaft or timing being off.... i don't want a ruined engine
1 - 4 of 4 Posts
