1 - 13 of 13 Posts
2016 ST3 Race Red
I bought a 2016 ST with 78k miles on it and one of the key fob (the one that appears to be used more often) does not work to unlock the doors or to turn on the car.
I replaced the battery on both key fobs and the irresponsive one is still not working.
Any light on what might be the cause?
PS.: I searched the forum but all the threads I found were about no key fob working.
I'm thinking you can sync it using the pad that is hidden inside the center arm rest- but perhaps I am mistaken. Your local Ford dealership can likely assist you, but I don't think they do anything for "free"...
That seems strange. Symptoms seem like BCM forgot one key.
I would double check the usual electrical culprits, good battery and connections, grounds, HCJB midi fuses, etc. And probably disconnect battery awhile, bleed residual voltage, reconnect before I took to dealer.
Possibly the fob is no good.
Reactions: SSgtjrobertson
Probably a broken/worn out fob. You can't reprogram facelift fobs without the scan tool so buying an Amazon fob will require a visit and payment to either a locksmith or auto technician with a scan tool. If you bought it from a Ford dealer they should provide a second working key for free.
If you get 2 working again, you can pick up a cheap generic one off eBay for maybe $30+/- as future insurance to keep you out of the dealer. You have to match up those tiny numbers under the fob key cover to be sure it will work.
If you have 2 working ones, you can program up to 6 more, 8 total, yourself.
...If you have 2 working ones, you can program up to 6 more, 8 total, yourself.
@MtnMan That’s awesome!! Do you have the link to the procedure for how to program fobs 3-8? 👍
I don't have a ready link, but do remember it's in the owner's manual. I had to try it at least several times on the cheap eBay 3rd key I got, varying speed slightly before it took, but it wasn't difficult.
I haven't used it much, I just check it occasionally to be sure it still works.
for Ford Grand C-Max Focus Mondeo Kuga 2016 2017 2018 Remote Key Fob KR5876268 | eBay
2016 ST3 Race Red
I cleaned the car battery terminals and ground bolts and now both of the key fobs are working... not sure if this is what solved the problem or if the more used key fob is working intermittently, so I'll keep using the less used one and keep the more used at home as backup if needed. I really don't want to have the key fob stopping working when I'm far from home.
Do you have the actual door key? It Lives inside the fob. Also, do you know about the place in the center console to place your fob In order to start the car in the event of a failure ? Point is, You should be fine as long as you know these safeguards.
Reactions: MtnMan
...Also, do you know about the place in the center console to place your fob In order to start the car in the event of a failure ?...
I’m unaware of this. Please, do tell.
2017 Kona Blue ST1
Flat Transponder pad inside the bottom of center console. Reads the Key fob with or without electrical assistance. Exactly like the transponder ring around a standard ignition switch that reads the passive chip on the key.
Reactions: beretta96
Yeah i believe in your guys' facelift cars theres an outline of the fob in the rubber pad at the bottom? Simply set the key in the outline.
My PFL has a cover and a receptacle in the column to stick the fob.
1 - 13 of 13 Posts
