I did a really stupid thing today. I was prepping my turbo for the install this weekend, and while making sure all the fittings were tight, I snapped off the boost fitting for the oil feed line.
I'm gonna get it out with a hand-bolt extractor.
I really wanted to get this installed this weekend. I have an anodized blue aluminum fitting (same size, same oil restrictor) that will be here Friday. Is there any reason that this would not be a good idea to use? (e.g. the oil line and the aluminum cause some kind of chemical corrosion, or the aluminum will not hold up to the heat)
